宏指令通讯帧丢失
发表于 2014-5-10 22:09:32 | 显示全部楼层 |阅读模式
原来的
  1. SetData(one, "pcm", 0x, 1#102, 1)------A
  2. SetData(one, "pcm", 0x, 2#102, 1)------B
  3. SetData(one, "pcm", 0x, 3#102, 1)------C
  4. SetData(one, "pcm", 0x, 4#102, 1)------D
  5. SetData(one, "pcm", 0x, 1#101, 1)------E
  6. SetData(one, "pcm", 0x, 2#103, 1)------F
  7. 04050065FF00        9C70
  8. 01050065FF00        9C25
  9. 02050065FF00        9C16
  10. 03050065FF00        9DC7
复制代码
结果屏只发出了前面4帧,后面两帧丢失
调整后
  1. SetData(one, "pcm", 0x, 1#101, 1)------E
  2. SetData(one, "pcm", 0x, 1#102, 1)------A
  3. SetData(one, "pcm", 0x, 2#102, 1)------B
  4. SetData(one, "pcm", 0x, 2#103, 1)------F
  5. SetData(one, "pcm", 0x, 3#102, 1)------C
  6. SetData(one, "pcm", 0x, 4#102, 1)------D
  7. 屏发送
  8. 04050065FF00        9C70
  9. 01050064FF00        CDE5
  10. 01050065FF00        9C25
  11. 02050065FF00        9C16
  12. 02050066FF00        6C16
  13. 03050065FF00        9DC7
复制代码
屏发送正常。
GMT+8, 2025-5-13 15:07
