数值修改后发送问题
发表于 2014-2-19 08:43:59 | 显示全部楼层 |阅读模式
//数值改变后写入数据到仪表
//发送子程序
sub unsigned short SJX(unsigned short A, unsigned short  B)
unsigned char command[32],response[32]
unsigned short address, checksum,result
  short return_value
FILL(command[0], 0, 32) // 初始化command[0]~command[31] to 0
FILL(response[0], 0, 32)
command[0] = 0x01 // 站号
command[1] = 0x10 //写寄存器 (功能码是 0x10)
address = A// 起始地址是A
HIBYTE(address, command[2])
LOBYTE(address, command[3])
HIBYTE(B, command[4])
LOBYTE(B, command[5])
CRC(command[0], checksum, 6)// CRC校验计算
LOBYTE(checksum, command[6])
HIBYTE(checksum, command[7])
OUTPORT(command[0], "SB194E", 8)// 发送写命令
INPORT(response[0], "SB194E", 8, return_value)// 读取回复的命令
return result
end sub
//如果两次(间隔)的数值不一样,则调用子程序发送修改后的数值
unsigned short X,B
GetData(X, "Local HMI", LW, 1, 1)
DELAY(1)
GetData(B, "Local HMI", LW, 1, 1)
if X<>B then
unsigned short A=1
SJX(A, B)
以上程序数值修改后不能发送(没反应),错在哪里,该怎么改,麻烦师傅解答
另数值修改后发送有何办法,
OUTPORT和INPORT只能用在PLC类型为Free Protocol中吗,谢谢
GMT+8, 2026-11-14 15:19
