宏指令的高手来看看
发表于 2016-8-21 23:57:23 | 显示全部楼层 |阅读模式
short D,X,Y=1,Z=0,E=100,F=31950,G,H[4]={0,0,0},U
bool W=false
GetData(U, "Local HMI", LW, 9050, 1)
GetData(X, "Panasonic FP", DT, 99, 1)
if X==0 then
SetData(H[0], "Panasonic FP", DT, 47, 3)
SetData(H[2], "Panasonic FP", R, 21A, 1)
else
SetData(E, "Panasonic FP", DT, 47, 1)
SetData(F, "Panasonic FP", DT, 48, 1)
SetData(G, "Panasonic FP", DT, 49, 1)
SetData(Y, "Panasonic FP", R, 21A, 1)
SetData(D, "Local HMI", LW, 9200, 1)
哪位老师帮忙解答一下,这是一个配方传送的宏程序,帮忙解答一下,这个数据处理过程
发表于 2016-8-22 15:13:34 | 显示全部楼层
指令比较简单  就是字面理解判断传送 只是很多变量都没有来源 感觉不完整
 楼主| 发表于 2016-8-29 13:45:16 | 显示全部楼层
能讲解一下吗?
 楼主| 发表于 2016-8-29 14:21:53 | 显示全部楼层
大体程序是这样的,是一个配方数据保存调用的程序,能帮忙价格注释吗?
bool W=false
GetData(U, "Local HMI", LW, 9050, 1)//U变量是当前窗口编号
GetData(X, "Panasonic FP", DT, 99, 1)//X变量是当前配方编号
if X==0 then
else
SetData(D, "Local HMI", LW, 9200, 1)//赎值1给地址索引寄存器0#
if X==1 then
G=100
D=0
SetData(Y, "Panasonic FP", R, 320, 1)
else
SetData(Z, "Panasonic FP", R, 320, 1)
if X==2 then
G=200
D=100
SetData(Y, "Panasonic FP", R, 321, 1)
else
SetData(Z, "Panasonic FP", R, 321, 1)
if X==3 then
G=300
D=200
SetData(Y, "Panasonic FP", R, 322, 1)
else
SetData(Z, "Panasonic FP", R, 322, 1)
if X==4 then
G=400
D=300
SetData(Y, "Panasonic FP", R, 323, 1)
else
SetData(Z, "Panasonic FP", R, 323, 1)
if X==5 then
G=500
D=400
SetData(Y, "Panasonic FP", R, 324, 1)
else
SetData(Z, "Panasonic FP", R, 324, 1)
if X==6 then
G=600
D=500
SetData(Y, "Panasonic FP", R, 325, 1)
else
SetData(Z, "Panasonic FP", R, 325, 1)
if X==7 then
G=700
D=600
SetData(Y, "Panasonic FP", R, 326, 1)
else
SetData(Z, "Panasonic FP", R, 326, 1)
if X==8 then
G=800
D=700
SetData(Y, "Panasonic FP", R, 327, 1)
else
SetData(Z, "Panasonic FP", R, 327, 1)
if X==9 then
G=900
D=800
SetData(Y, "Panasonic FP", R, 328, 1)
else
SetData(Z, "Panasonic FP", R, 328, 1)
if X==10 then
G=1000
D=900
SetData(Y, "Panasonic FP", R, 329, 1)
else
SetData(Z, "Panasonic FP", R, 329, 1)
GMT+8, 2026-11-21 07:08
