怎么用HMI的宏指令实现一键启停逻辑
发表于 2021-10-4 19:12:19 来自手机 | 显示全部楼层 |阅读模式
怎么用HMI的宏指令实现一键启停逻辑
发表于 2022-6-23 11:16:50 | 显示全部楼层
bool a[2],QB_lamp,MB_Rising_edge
bool on=1,off=0
GetData(a[0], "Local HMI", LB, 0, 1)
//产生上升沿
if a[0] and not a[1] then
MB_Rising_edge=1
//启动自锁
GetData(QB_lamp, "Local HMI", LB, 10, 1)
if ( MB_Rising_edge and not QB_lamp ) or (not MB_Rising_edge and  QB_lamp) then
SetData(on, "Local HMI", LB, 10, 1)
else
SetData(off, "Local HMI", LB, 10, 1)
//复位上升沿和保持
MB_Rising_edge=0
a[1]=a[0]
GMT+8, 2024-5-16 18:04
